It's the sort of gulley formed where the inlet manifold meets the lip on the edge of the housings. There is a very small puddle of coolant gathering there, in roughly the area shown by the red arrowed box on this 'ere picktcher;
Sooooo, what's leaking there, then? It's been suggested that one or both of the coolant way O-rings has failed/is failing and the gasket isn't man enough to withstand the leak when it all gets hot. Does this sound likely? Stupid question, but what is the inlet mani gasket made from? If I pull it off to investigate, is it going to mutilate the gasket and I'll need a new one? Looks straightforward enough to just un-bolt the mani and pivot it up out of the way without even having to disconnect everything but I don't want to start this and then find I need to wait three weeks trying to find a new gasket that no-one make any more.
Opinions welcome, both on the cause and fix. Ta vurrah much
