S2 oil cooler
Johnnyboy
S2 oil cooler
Post by Johnnyboy »
Hi Guys. I am having a bad week....
Oil cooler is leaking (S2 - under the radiator....)
Difficult to tell where from, but the whole thing looks manky so I was thinking of one of these:
http://www.ebay.co.uk/itm/aluminum-oil- ... 415b0ea3f7
Any better ideas?
And any suggestions how easiest to fasten it in, since the metal/rubber brackets that hang it from the radiator have fallen apart....
John
Re: S2 oil cooler
I'd be more inclined to fit one of these.....
http://www.ebay.co.uk/itm/MAZDA-RX7-FC- ... 2ebb9a2abf
it's a proven rotary oil cooler, easy to mount up by hanging it off the round front beam in front of the radiator with some exhaust U-bolts and will then give the option of putting in a larger s3 radiator in the future as the cooler won't be underneath the rad.
You'd need to get some longer lines made up though.
BO0557
Re: S2 oil cooler
Post by BO0557 »
have to agree with Ian there - ive done away with the beehive and gone with the FC oil cooler with some nice -10 AN braide speedflow lines and havent had an issue..
With doing the U bolt install like above the oil cooler is upside down i believe also but still works effectivly.
Has thanked: 156 times
Re: S2 oil cooler
John, what oil cooler did you go for in the end ?
Re: S2 oil cooler
Currently wrecking an FC ;)
Re: S2 oil cooler
TOOL wrote:Currently wrecking an FC ;)
That sounds just what I want, is the cooler sound if so I'll have it.
Re: S2 oil cooler
Post by RamoNZ »
ian65 wrote:I'd be more inclined to fit one of these.....
I am using FC lines in mine and they reach OK - This is a 13b though, but they should be the same thread as 12a...
Re: S2 oil cooler
is yours slung under the front beam like Tims is Ramon?
Been thanked: 111 times
Re: S2 oil cooler
Post by Chud »
I think you'll find the stock cooler comes with a thermostatic bypass built in so the oil gets to temperature first. Go with the FC unit - two U bolts and a foot or so of 4mm flat bar and job done.
Re: S2 oil cooler
1st gen air cooled oil coolers are mega money new and all the 2nd hand ones are shagged.
Tools cooler off the turbo2 is the way to go.... if it'll handle the oil temps on a turbo2, it'll sort an Elford no problem.
Return to “Cooling”
