So as I've been saying, the FB was in need of better lighting. I searched through the junkyard and found some pretty decent halogen foglights on a Z28 Camaro that featured aimable brackets. (And just in case, I also grabbed another set of brackets off another Camaro)
Then I went about mocking up how I was going to mount them on the car, which took a while... but I think this design works well. I'm using both sets of brackets, two of which I had to hammer flat. It's very solidly mounted, bolted directly to the aluminum bumper and also the bumper support bracket. I designed it so that if the bumper does get jammed in on its shocks for whatever reason, the brackets connecting it to the bumper support will separate and not damage the foglights or the brackets. (In theory anyway...)
I bought new bulbs for em, along with new headlights and aimed them up against the side of Walmart after it got dark. Should work way better now, but I still want to add in some high powered auxiliary lights to throw light further down the road.
