cooling system refresh....
richrx
Has thanked: 31 times
Been thanked: 31 times
Re: cooling system refresh....
Post by richrx »
TOOL wrote:Chances are it's the inlet manifold gasket and the 2 rubber orings on the housings are knackered.
It should be 6 studs holding the manifold on. 2 on each end plate and one on each housing. Nothing on the middle plate.
If it's not that, check for leaks on the thermostat housing as water can dribble down from there an pool on top of the manifold.
Thats exactly the problem I had last night, 2 sneeky bolts! thankfully the engines on a bench, seems a nightmare of a job if it was in the engine bay still!!
I'll go whip those bolts off, the thermostat seems fine for leeks, looking at where the crystals are formed im thinking its definitely the manifold leaking somewhere.
Of the 4 bolts I removed from the inlet one or two had rusted threads, think theres any hidden problems? Or is that normal?
I'm losing the plot. Yeah, bolts on the end plates.
Just clean them up with a wire brush or wire wheel, they'll be fine. I use a little spray grease on bolts too.
You can also seal the housings using freeze plugs.
TOOL wrote:Where's this screw?
No, you're right Tool, it's the 2 underneath the inlet manifold into the housings that are hidden from view.
Rich....No signs of 'O' ring failure or gasket failure then?
richrx
Post by richrx »
Hi
Ok managed to get the inlet off, and YUK! Its a mess... the o-rings crumbled when I took the manifold off so definitely failed :p the gasket doesnt look at its best either.
I had a clean up of the iron around the area and I'm not too sure on the condition, its really tough to identify whats the block and whats baked on coolant.
Finally when I took off the inlet I found thos spacer ontop of the thermo reactor, does it belong on the inlet somewhere or has it just fallen and landed here previously?
Finally finally trying to remove the waterpump housing from the front of the engine, is their an easy way or does the main pully have to come off with that large bolt in the middle of the pully...?
richrx
Post by richrx »
Random spacer found, can anyone identify where it should be? (hp) ...
Inlet manifold NEEDS CLEANED! :O
richrx
Post by richrx »
What do you think of the condition? I think I cleared most of it fron the rear iron, but the pitting is worrying me :s
richrx
Post by richrx »
Just because I like it :D
Yeah, that's goosed.
Spacer goes on the alternator mount with the bolt going through it by the looks of it.
Holy cow, that inlet mani looks like it's been dragged up from the bottom of the sea :shock: Did you actually find any barnacles? :?
A thousand apologies about the cooling fan, it completely slipped my mind over Christmas with one thing and another :oops: My bad. PM me an address and I'll get it posted asap if you still need it?
You'll not be leaving the thermal reactor on are you Rich. If not I should whistle it off now, on the bench, before you put the inlet manifold back?
If you put the inlet back first, the top left bolt on the reactor is the worst access of any bolt, on any car, anywhere.
Dunno what to say about the corrosion. Someones really messed up on their cooling system maintenance.
What's your alternatives? paste it all up with gasket sealant and hope for the best? Or what else?
Return to “Cooling”
