Body restoration history of my 1980 RX7
Kriton
Re: Body restoration history of my 1980 RX7
Post by Kriton »
Luckily, the doors were completely rust-free
That's an inspirational amount of work right there :shock:
Kriton
Post by Kriton »
The car ready from the paint job.
detail
detail
Pitty the car looks a bit dusty in the photos. (Because of streetwork outside the Garage the car became dusty after the painjob and before I took photos).
Kriton
Post by Kriton »
Some more details. All trims were painted separately.
Kriton
Post by Kriton »
After some hesitation (of financial nature) I decided to restore the interior, as well. The original one was in decent condition but after some thought (or rather acting emotionally) I decided to go for the interior restoration. So, besides the paint job I had to strip the car internally.
Judging from the result this was proved a good idea. Another nasty surpise was there for me to discover.
Some corrosion on the pan under the rear seat.
red circle to indicate the corrosion spot
Kriton
Post by Kriton »
The good thing was that all the rest was absolutely clear (no sings of rust elsewhere!).
the rear wheel well - Perfect!
Kriton
Post by Kriton »
Rust damage fixed!
002 small (2).jpg (109.44 KiB) Viewed 5343 times
001small (3).jpg (116.83 KiB) Viewed 5343 times
Kriton
Post by Kriton »
Interior was done by a specialist. He started with the roof wall.
May-June 2013 small 001.jpg (64.42 KiB) Viewed 5342 times
May-June 2013 002small.jpg (47.5 KiB) Viewed 5342 times
May-June 2013 004small.jpg (66.44 KiB) Viewed 5342 times
Kriton
Post by Kriton »
Exterior was also progressing. I had to buy some trims.
New front a rear badges
May-June 2013 003 (3)small.jpg (45.35 KiB) Viewed 5342 times
Ruber seals that goe underneath the rear lights (the original were falling apart (completely decomposed after all those years)
May-June 2013 001 (3)small.jpg (53.99 KiB) Viewed 5342 times
The two back wheel arches under the back seat is where trouble is usually spotted. If you have an FB then sooner or later you'll meet it.
