C584FAX
User Banned
Re: Mick's Red S3; New hoops!
Tuff car! Did you say 480hp?? Wow! What intake manifold/ intercooler/turbo set up have you got going on there? I don't think I've ever seen anything like that!
mc turbo
hi joe 480bhp was on my T2 running 1.4 bar with a hks TO4Z, W. Inj & large st port but now going semi pp! my fb is 200bhp cheers mickJoe Blow wrote:Tuff car! Did you say 480hp?? Wow! What intake manifold/ intercooler/turbo set up have you got going on there? I don't think I've ever seen anything like that!
mc turbo
hi guys just a little update im in discussions with grant monkhouse on mrc to buy his brand new never run full bridge ported T2 engine with gt35r turbo , as I have all the the mounts from the red elford donor fb which had a T2 engine in it but had water & oil seal problems so ive got all the custom mounts & prop shaft to fit my fb so hopefully it will b brap brap time
if Monkhouses engine was built by Hayward, make sure you keep your existing engine as a spare........ you'll probably be needing it.
lol. As I recall the last Hayward bridgeport seen in public was in their "drag" car... presumably so called because it was a right drag. Maybe there was a reason Mazda went to all those tedious lengths to develop water seals after all
mc turbo
hi ian is there something wrong with monkhouses bridge engine? or is it who built it? ps. would it b better to rebuild my T2 block? & who would u recommend to rebuild it ? cheers mickian65 wrote:if Monkhouses engine was built by Hayward, make sure you keep your existing engine as a spare........ you'll probably be needing it.
apexheid
Oldone Racing.mc turbo wrote:hi ian is there something wrong with monkhouses bridge engine? or is it who built it? ps. would it b better to rebuild my T2 block? & who would u recommend to rebuild it ? cheers mickian65 wrote:if Monkhouses engine was built by Hayward, make sure you keep your existing engine as a spare........ you'll probably be needing it.
mc turbo
hi nik do u not recommend bridgeports ? or the guy who built it?Lucky wrote:lol. As I recall the last Hayward bridgeport seen in public was in their "drag" car... presumably so called because it was a right drag. Maybe there was a reason Mazda went to all those tedious lengths to develop water seals after all
