What am I missing now?!
I've got an errant hose coming out of the intake manifold. It starts metal, changes to rubber, and ends in metal, and goes nowhere... what is it?
- 2015-06-23 20.43.28.jpg (118.66 KiB) Viewed 3843 times
- 2015-06-23 20.43.01.jpg (168.71 KiB) Viewed 3843 times
- 2015-06-23 20.41.59.jpg (109.17 KiB) Viewed 3843 times
Re: What am I missing now?!
Think you're indicating an air pipe. From the factory this ran back as a small pipe with a stainless bellows section where yours has been made rubber. From memory this pipe went into the side of the first silencer on the factory exhaust.
When people fit a replacement exhaust the air pump and thermal reactor system are removed This pipe is also taken off. (90% of owners have done this).
Usually it's blanked at the manifold.
economiser
I was going to guess coolant-related. But then it should drip. Just make sure it's not a massive vacuum leak, or it'll never run.
I thought coolant at first too but it doesn't leak, so air hose... hmmm I guess I'll just remove it and cap it off. I don't think it's a vacuum leak cuz she runs.
