That is the million dollar question ............. only time will tell..............TOOL wrote:Result, but do they fit?
KYB Front Shock Absorbers
Re: KYB Front Shock Absorbers
Yup, good luck buddy.
- DKWW2000
- Has thanked: 183 times
- Been thanked: 187 times
Well done Dave, my lack of faith will have cost a few days as mine (according to DHL Tracking) are over the Atlantic somewhere due in on Wed!
- DKWW2000
That would be goodA7RXY wrote:Andy Hopefully Pete will fit his first and do all the donkey work ...
I have greased my spring compressors & lubricated my nuts
- DKWW2000
Re: KYB Front Shock Absorbers/LACK OF
Well sometimes you start down a path that looks easy with no obstacles like buying front struts.DKWW2000 wrote:Well done Dave, my lack of faith will have cost a few days as mine (according to DHL Tracking) are over the Atlantic somewhere due in on Wed!
Having told that mine were on route to UK I get a message that they have been "Returned to Sender" due to incorrect customs documentation
Not one to give up easily & having had a 3rd refund from companies unable to complete the sale I bought again from another company this time using using the Global Shipping Programme
Yesterday a Box duly arrived feeling a bit under weight, so upon opening I found 1 x Strut having paid for 2
I have now contacted Ebay & as the weight was kindly recorded by the courier it proves there could not have been 2 inside, also when I purchased they said they had only 2 (by email & listing) and now their listing is showing "Last 1 available"
4 times I have now tried and failed to buy 2 struts, on the bright side I am 50% there, the god of Distance buying is having his fun. F--$*?@£ZQ
It is now a matter of honour that I WILL HAVE 2
- A7RXY
- Has thanked: 156 times
- Been thanked: 61 times
These struts are getting harder and harder to get hold of, as said before it has taken me 2 years to get mine having been let down a number of times, so only time will tell Pete until you get yours.
I noticed today that RB are advertising them on their European site at £90 + each but I wonder if they actually have any ?
- Has thanked: 473 times
- Been thanked: 253 times
What mod to fit the bilstein insert?TOOL wrote:Check this out: Re 944 struts.
http://www.ebay.de/itm/Stossaempfer-Bil ... 1792642643
- DKWW2000
Being a wimp I have been waiting for it to get warmer before I attempted the front strut change (having taken 4 months to source see earlier threads) today was the day!
I did the front right today so can report the KYB fit OK with the aid of a small O ring.
The only problem problem was getting the nut off at the top of the old strut. After several attempts with mole grips as per Ian's Topic :-
http://www.rx7fb.com/viewtopic.php?f=8&t=470
I got a 9" Grinder & cut straight through the shaft -
Job done.
Once the new Strut was inserted into Tube there was a little free play so I used a O ring to take up the small gap to stop it rattling.
Whilst I am in that area working I am going to change some of the suspension bushes as I found a complete set of Super Pro on EBay AUS for £85 as packaging was damaged & £18 postage via Sea
Over to you Dibs -
No excuse now
Over to you Dibs -
