'80 13BT Series 1
- Has thanked: 476 times
- Been thanked: 253 times
Re: '80 13BT Series 1
Seems you will have more fun with toyo kokyo then VW as i can see your torque curve
Hope the car is drive-,payable- and durable.
- Has thanked: 3 times
- Been thanked: 111 times
Yeah I hope so cheers Thomasspirit r wrote:Seems you will have more fun with toyo kokyo then VW as i can see your torque curve![]()
Tool how much will that diff take you think?
Cheers for all the messages.
It'll take 200hp, maybe 250hp. Basically it'll take most NA 2 rotors.
Depends how brutal you are.
Axles are the weak link. Get a Torsen and some 26 spline axles made. Thatll be much stronger.
I was told the diff will take in normal temperature range max torque between 400-500 nm.Chud wrote:spirit r wrote:
So you push it to higher Temperature you should cool them down with a oilcooler and 12V oilpump.
Or weld an extra reservoir into the housing.
You'll still be stuck with small splines and small axles though and cooler oil won't save the diff and axles.
Depends of the weight of the car and grip of the tires also Andy. Don't forget the more lightweight "cud" s1 produce wheelspin before destroy the axle . FC and Fd are more heavier.TOOL wrote:Or weld an extra reservoir into the housing.
Correct me so i am wrong.
- DKWW2000
- Has thanked: 183 times
- Been thanked: 188 times
Look forward to seeing this at RRG, are you taking it up the hill
biznatch
That's one tough beast! Been reading back through the build thread with great interest.
that's awesome
you need a LSD to put that power down....... it's gonna be a right handful.
