Finally got a bit of an update on this, it's moving along slowly constrained by time/budget but it's nice to have things moving again. At the moment, the car looks like this:
I have almost finished stripping everything from the underside of the car - this is to check the condition of the shell and treat it with POR-15, install polybushes and check/paint suspension components. I will also need to modify the fuel tank to accept an in-tank FI pump, I am thinking about doing something along these lines:
http://www.gearhead-efi.com/gm-ecm-pcm- ... rsion.html
The underside looks pretty good, I've only found one small hole in the sill so far:
The condition of the shell generally looks good:
Axle and fuel tank out:
Using a DIY puller to remove the suspension bushings, which thankfully all came out without too much of a fight:
Suspension parts ready for sandblasting/painting/polybushes:
As well as the chassis side of things I have been doing bits and pieces to get the TII engine ready. Blanking plate for some of the emissions kit made redundant by the Megasquirt made up and fitted to upper inlet manifold:
Dodgy old alarm and redundant emissions/ignition wiring traced through the engine bay loom and removed, to be replaced with new DIYAutoTune loom:
And finally on a work trip away, I couldn't bring the car but I could bring a soldering iron and a Megasquirt MS2 kit with a Zeal daughterboard and boost control modkit. JimStim & MS assembled and tested:
That's more or less up to date, things have been happening in a slightly strange order due to time/budget/lift availability but I'm trying to chip away at it when I can. If anyone needs any ignition stuff stripped from the old 12a please feel free to give me a shout, also I'll be ordering some bits from the US in the near future and would be able to shove some more small/light bits in the box, so if anyone needs anything let me know!
