C160SFG - 1986 Series 3
- DKWW2000
- Has thanked: 125 times
- Been thanked: 118 times
A lot of good work going on there Ian, it must be satisfying when you overcome these hurdles through your own initiatives & engineering
- Has thanked: 232 times
- Been thanked: 276 times
thanks, to be fair I'm following Bumpstarts instructions on flipping the manifold..... it all looks a bit tight though so I might just end up buying another manifold.
- myatt1972
- Has thanked: 29 times
Great work Ian
I can't believe those gaskets are £50, thats bloody daylight robbery !
Took the car out for a spin today in the sunshine but it's running like a dog. It fires up on one rotor, occasionally the 2nd rotor will kick in and it struggles to pull away.... chugs along the road then every now and again it picks up and drives great, mainly when the revs are up but when I slow down and the revs drop, it seems to go back onto 1 rotor again.
When it's up on the rev and the turbo kicks in it flies so it isn't mechanical/compression or else it would be chugging all the time. The induction system fuels both rotors simultaneously so it can't be a fuelling issue as the rear rotor is running fine.
I pulled the plugs and cleaned them up... all were ok ish but the plugs on the front rotor were wet so that pointed to an ignition issue on the front rotor. I've changed the plug leads and the dizzy cap but it's still the same...... any other thoughts? Presumably the ignitors are split between leading and trailing, not front to back?
- DKWW2000
Sounds like fouled plugs Ian.............
I did clean them Pete but I'll put some brand new ones in and try that, thanks
changed the plugs for these brand spankers....
and still the same... flat, hesitant and gutless
- MelloYello
- Has thanked: 18 times
- Been thanked: 47 times
Have you used timing light to see that you are getting spark to each plug?
- Has thanked: 300 times
- Been thanked: 146 times
Coils or coil wires (leading most probably) or ignitor plug connections on the side of the dizzy?
