KIMI - Series 2/3 Hybrid
Has thanked: 443 times
Been thanked: 324 times
Re: KIMI - Series 2/3 Hybrid
Wheelarch before:
Before work 2.JPG (214.8 KiB) Viewed 8404 times
Before work 6.JPG (277.35 KiB) Viewed 8404 times
Derusting:
Initail prep 3.JPG (284.16 KiB) Viewed 8404 times
Initail prep 4.JPG (229.06 KiB) Viewed 8404 times
Initail prep 5.JPG (261.25 KiB) Viewed 8404 times
Initail prep 14.JPG (252.97 KiB) Viewed 8404 times
POR15 pre-treatment (de-grease and acid etch):
Final acid etch 2.JPG (207.36 KiB) Viewed 8404 times
Final acid etch 3.JPG (235.06 KiB) Viewed 8404 times
Final acid etch 6.JPG (203.21 KiB) Viewed 8404 times
Final acid etch 8.JPG (219.36 KiB) Viewed 8404 times
POR15 applied
Offside wheel arch 021.JPG (141.64 KiB) Viewed 8404 times
Offside wheel arch 024.JPG (154.58 KiB) Viewed 8404 times
Offside wheel arch 025.JPG (185.14 KiB) Viewed 8404 times
Offside wheel arch 028.JPG (160.09 KiB) Viewed 8404 times
Offside wheel arch 029.JPG (169.75 KiB) Viewed 8404 times
Offside wheel arch 031.JPG (203.02 KiB) Viewed 8404 times
Rear Axle and Diff:
2014-06-13 11.46.16.jpg (222.31 KiB) Viewed 8403 times
2014-06-13 19.55.01.jpg (193.12 KiB) Viewed 8403 times
2014-06-13 19.55.39.jpg (232.87 KiB) Viewed 8403 times
2017-01-09 14.08.29.jpg (510.9 KiB) Viewed 8403 times
Suspension arms.
Before :shock :o :o
Rear Bush Before.jpg (81.06 KiB) Viewed 8402 times
WIP:
Suspension bolts re-plated using a "Gateros" kit. These were the first few I did, not perfect, but I got better at the process with the later bolts.
2015-01-09 15.29.37.jpg (208.49 KiB) Viewed 8401 times
2015-01-09 15.31.27.jpg (156.73 KiB) Viewed 8401 times
Rear brake calipers:
One before:
DSC_0027 (2).JPG (235.15 KiB) Viewed 8399 times
After Bigred refurb:
Porters2
Has thanked: 85 times
Been thanked: 124 times
Post by Porters2 »
s(c)
Looking bloody brilliant Malcolm 👍
Has thanked: 441 times
Been thanked: 181 times
Far out bro. That is all looking sweeeeeeeet!
Been thanked: 88 times
Good work Malcolm :thumbup:
Thanks guys!
The rear brake stone guards were in a bit of a state, with missing bits and holes. I'm not too proud of the bodge I have made to make them at least functional, but at least they are not easily visible and will do the job.
Before:
2017-04-07 16.57.45.jpg (629.59 KiB) Viewed 4131 times
Aluminium plate cut to size:
2017-08-22 17.15.23.jpg (486.03 KiB) Viewed 4131 times
Replacement parts made. Ali shield pop-rivetted on, stainless steel strip curved around edge, POR 15 and sealant applied:
2020-05-18 19.20.19-1.jpg (168.84 KiB) Viewed 4131 times
Mounted back on the axle:
2019-04-19 13.50.10.jpg (242.84 KiB) Viewed 4131 times
New brake lines installed:
2019-04-20 15.11.35.jpg (289.93 KiB) Viewed 4131 times
