anyway on to pics.....this is what was pulled and what was left over, just to give a lil scope of whats involved
and all this could not have been possible without the factory manuals on pdf and
drivers pocket showing re-routing of main loom, the relays arent bolted in(still need to paint engine bay), still need to loom main power wire (red), and route a/c harness (leaving out of the "tucked" harness should I choose to remove later on, and WASH the inner fender!
still have some various repair work to do, battery pocket is where leading ignition system will mount, but once cleaned and painted will be much cleaner looking than factory.
pic showing main harness routing and unfinished ignition harness
plugging EVERYTHING to do with lighting/flashers/windshield washer pump & level/ignition/charging in where they go
connected the battery and turned the key
now to check all the lights
parking rear check! ground in background was the one I missed!
parking and headlamps (had bulbs plugged in before I remembered to snap pic)
left front signal check! pic snapped just as it was dimming
left rear check!
right front check!
right rear check!
reverse check!
factory amps and harness
next week I'm going to work on this, blasters in the factory coil spots and trailing coil on an aftermarket mount!
