Page 2 of 2
Re: bought a set of 35mm PI lowring springs very dissapointe
Posted: Sun Jul 20, 2014 4:19 am
by mc turbo
hi biz did u change the rear shocks as well? otherwise it could b ur old shocks r worn? mine seem fine it was just the small drop in height I was disappointed with, but ive got a full set of gaz coilovers to fit so it should b much better :mrgreen:
Posted: Sun Jul 20, 2014 10:01 am
by biznatch
The shocks were replaced with adjustable ones front and rear, both on the softest setting at the moment. Koni yellows in the front and KYB AGX in the rear. I know the ride should be much harder with the increased spring rate and dampening but the here is a noticeable difference between front and rear which leads me to think there is something wrong. I'll check the top mounts and Bumpstop clearance this afternoon and report back.
Posted: Mon Jul 28, 2014 9:08 am
by biznatch
Cut about 15mm from the bumps tops and the problem seems to have been solved now :D
