spoddy wrote:to be honest any half decent fb is going to be starting at £2000 upwards. it's the rust in the major areas which kills the body on them so you would be really better saving up for a really good one as you will spend it in the long run. there are some decent fb's in england from one grand upwards but you need to check under the rear seat, the sway bar areas in the rear wheel arches and chassis around the engine bay etc.
if i was going to buy an fb i would be saving up some more and buying one from £2000 to £3000. really, really mint ones from Japan would set you back £5000 upwards, but then no rust issues and you get the Jap spec fb's, later models had the 12a turbo or early 13b engines.
you only pay in the long run really so better buying a really good one at the start. check out the blue s2 on ebay.
yeah spoddy, ill keep an eye on the ebay for one in england..seems to be the most viable option as they are so rare down here..
