Tpm180x
- Has thanked: 629 times
- Been thanked: 222 times
Re: Tpm180x
Although I'm not keen on the MX5 swap into a 7 as it seems a bit pointless in my opinion.. I'd still like to see a build thread aye!
At least the shell is being saved. Have fun with it
- Been thanked: 188 times
Re: Tpm180x
I think you will lose the whole essence of the RX7, the Rotary engine is what makes it unique.
Rotary engines are a lot less likely to suffer catastrophic failure than a piston engine which is why they were liked so much in the aero industry as they tend to give plenty of notice when starting to fail & get you home.
All the Ro80s that had 12as fitted hold their value whereas the V4s etc lost all their value
That is my take on it but as long as the body stays intact you can always revert back
Best of luck with it anyway & will be interested in a build thread.
- myatt1972
- Has thanked: 40 times
- Been thanked: 37 times
Re: Tpm180x
Its your car do what you want with it, we all have our cars to enjoy them. Id be very interested to see the swap, I hope you will do a build thread.
mc turbo
Re: Tpm180x
hi m8 @ least turbo it to get double the power to make it worth while!Kevralpina wrote:well that did the trick I bought tpm because I like the early rx7 but that engine no if I hadn't got it the car would be scrap and yes I like 80s cars as I also have a Montrose coupe again with mx5 power and again saved from the crusher (the conversion transformed the car ) and as the rx7 will be a regular user it makes sense but each one to their own thanks
- Has thanked: 5 times
- Been thanked: 23 times
Re: Tpm180x
Regular user huh ? Six months later it is in Yorkshire and not even a sniff at £300..........Kinda proves what was said in the thread.Kevralpina wrote:well that did the trick I bought tpm because I like the early rx7 but that engine no if I hadn't got it the car would be scrap and yes I like 80s cars as I also have a Montrose coupe again with mx5 power and again saved from the crusher (the conversion transformed the car ) and as the rx7 will be a regular user it makes sense but each one to their own thanks
Kevralpina
Re: Tpm180x
Regarding tpm180x I sold the car via ebay around july time as another project came up it was sold to guy from up north who was going to convert it back and for a lot more than £300
