Page 2 of 3
Re: New to Rotary Ownership - Essex, UK
Posted: Tue Feb 02, 2016 3:48 pm
by biznatch
The accelerator pump should also help by squirting a bit of extra fuel in to smooth out the transition from primary to pri+ secondary opening. Check to make sure thats ok. There is a mod to increase the accelerator pump stroke which is usually done when changing to mechanical secondaries which might help too.
Posted: Tue Feb 02, 2016 4:42 pm
by biznatch
Does it rev more freely after about 4500rpm or still spluttering at higher revs?
Posted: Fri Feb 05, 2016 2:42 pm
by Matt_j_smith
It revs up ok through the range, but i cant floor it. I took it for a decent drive the other night. I could feel the secondariness opening at higher rpm without it bogging down loads but i had to be careful. I will check the accelerator pump this weekend. I can see two decent streams of fuel coming out when I just turn the throttle, and i can see the mech secondaries opening and closing when they should - so i deffo have a fuel issue somewhere. I am also going to double check for any vac leaks. The car also idles at 2000rpm? would that indicate anything?
Thanks!
Posted: Fri Feb 05, 2016 4:45 pm
by KiwiDave
Check for vac leaks again. There are a fair few sources to plug once the rats nest comes off. Standard idle speed is 750-800 rpm. So, either your idle is set way high or there is a (large) vac leak somewhere.
Posted: Fri Feb 05, 2016 7:14 pm
KiwiDave wrote: So, either your idle is set way high
To compensate for a poor tune or carb issues. 1000rpm should give a nice idle.
Posted: Sat Feb 06, 2016 12:34 am
by biznatch
Sounds like the acelerator pump is working ok from what you describe. Vacuum leaks can be tricky to locate and cause an erratic performance. There are a lot of tubes to be plugged or connected so it needs to be checked methodically. Perhaps you could post a few pics of the carb, hoses, linkages and manifold if you can?
If you drop the revs does it start to stall? 2000rpm is far too high an idle speed as Tool says. There are some good guides to tuning and resetting the Nikki once any vacuum leaks have been dealt with.
Posted: Tue Mar 01, 2016 1:15 pm
by Matt_j_smith
Hi all,
sorry for the very slow reply! Wedding planning and dissertation are taking over everything at the moment!
so the high idle turned out to be wonderfully simple!!! the linkage was a bit tight so the throttles weren't shutting properly. A few sprays of WD40 later, and sa slight 'modification' to the return spring and its dropped down to c. 800rpm.
I also took the carb off and gave whatever i could a decent clean ( without going ott - still not very expirenced and I wanted to drive it the next day) - It is now a hell of a lot better. still bogs down if i floor it but itdrives normals up until the flat out point.. its only when my foot is flat, all other times its fine!
so, apart froma small oil leak from the pan, a small water leak, an exhaust that needs some love and a sticky caliper its very much a decent driver.. or getting there!
Posted: Tue Mar 01, 2016 5:31 pm
by DKWW2000
Hi Matt welcome,
Do not forget the obvious, the main Fuel filter located underneath by the Diff/Fuel tank,often overlooked/easily blocked when tanks gets low and left for long periods,
regards Pete
Posted: Tue Mar 01, 2016 9:14 pm
Matt_j_smith wrote:so, apart froma small oil leak from the pan, a small water leak, an exhaust that needs some love and a sticky caliper its very much a decent driver.. or getting there!
Sounds like most of our cars right there, all perfectly normal.
Posted: Thu Mar 03, 2016 1:29 pm
by Matt_j_smith
Cheers Pete, I will have a look at that this weekend. i took it out last night fora short drive. went pretty well. started and stopped when it should! Filter is an obvious thing i should really do - cheers.
And yes - there's still a few things on the list to keep me busy lol
