Page 16 of 18
Re: '83 3.8L, 50 MPG, big brakes
Posted: Thu Jun 11, 2015 8:44 pm
by economiser
Posted: Thu Jun 11, 2015 8:53 pm
what sort of power output are you hoping for?
Posted: Fri Jun 12, 2015 1:12 pm
by economiser
ian65 wrote:what sort of power output are you hoping for?
The engine was 200 horses to begin with, so that's 170 at this elevation. My cold air induction and exhaust system may add a few, but where the exhaust manifolds dump into the pipes is still restricted, so I see little chance of it exceeding 200. Not that the owner cares, while both of my own projects have the 4.8L version of GM's LSx V8.
Not that I expect anyone to be interested, but my S-10 started in this thread:
http://ecomodder.com/forum/showthread.p ... 29947.html
and is now in this thread:
http://www.s10forum.com/forum/f219/87-t ... on-701194/
Posted: Fri Jun 12, 2015 7:58 pm
by KiwiDave
First to admit that I know zip about S 10 pickups but those mpg figures are impressive. Especially how mpg increased after adding the least aerodynamic airdam that I've seen for a long time. It's a different world for sure!
MPG and rotary is never going to be a positive conversation sadly.
Posted: Sat Jun 13, 2015 1:35 am
by economiser
The new M12 x 1.5 x 30, grade 10.9 bolts arrived, so here's a better view:
that's 5/8-inch 6061-T6 aluminum, roughly 1.375-inch in this case, with an offset of 0.106-inch.
Knowing the brakes can never be insufficient is worth the couple hundred extra dollars. The tires may prove to lack grip, but that's a separate matter. Likewise boiling the brake fluid.
Posted: Sat Jun 13, 2015 10:37 pm
by economiser
Finally had everything ready for brake fluid, and the right rear bleeder was open. Then, the left rear wouldn't open. So after the socket destroyed the hex part, I tried Vise Grips, genuine Irwin brand. A dozen tries later, the remains broke. So now I gotta spend more on a reman caliper, plus shipping mine in.
I must assume this caliper is the reason why, with the other corners bled, the pedal still feels like it releases pressure just before bottoming. I don't like this. GM brake masters divorce the fronts from the rears, so even if you lose one end you still have the other. Mazda was too fart-brained.
Posted: Sun Jun 14, 2015 12:14 pm
by codge
I might be wrong here but I thought most cars had split circuit brakes from around the 1970's?
Posted: Sun Jun 14, 2015 11:40 pm
by Hobbawobba
myatt1972 wrote:Things look pretty tight in there
Will be interesting to see how it performs, keep the pics coming.
+1 must of been heaps of measuring aye
Nice progress
Posted: Mon Jun 15, 2015 12:44 pm
by economiser
I thought so too.
Packaging was more about test fitting what had to go in, in sequence.
Exactly 3 weeks until the show begins, much needs done, and I can't slow the clock.
Posted: Wed Jun 17, 2015 7:51 pm
by economiser
