Re: Rexanne!
Posted: Sat Feb 23, 2013 12:44 pm
				The car's been running great, so I've taken the opportunity just to do a couple of small little jobs.
First up, I want to do a track day at Castle Combe in the spring, so I took the car up there to see if it'd meet the 100db static noise test. Which it did... just! Having got 99.7db, the scrutineer advised me to cut off the down turned tailpipe so a bolt on racing muffler can be fitted if for some reason the car is slightly louder on the day!
I think I'll get a bit of stainless pipe to extend the 'stump' out a bit, as the exhaust exit is pretty tucked under the car now.
Whilst I was under there I noticed a cracked exhaust rubber, which wouldn't have been helping with the occasional knock.
So that got sorted with a new one.
Next up, the 'dealer issue' front number plate was annoying me because it's massive and also quite beat up.
So I ordered a fancy-dancy pressed aluminium plate that's the same size and type as the ones they have in Japan...
Finally, the battery terminals were badly designed, all knarled up with repeated use and too big for the posts on the battery, so I replaced them with some of the 'quick release' type I had... much better!
So then it was time for a wash and wax (the car not me, I didn't fancy the 'back, sack and crack'!!) then off for a quick 'test drive' and some pics.
