THE AUSSIE RESTO SER III
m swann
Re: THE AUSSIE RESTO SER III
Post by m swann »
[quote="HDT143"]Me and my brother hand rubbed all the factory paint off back to the primer
I would be interested in a more detailed description of this.
When grit type. wet or dry, and how do you know when to stop.
I have a number of panels with multiple layers and would like to try this.
Mal
When in doubt....hit the gas.
HDT143
Post by HDT143 »
Mate we used 280 wet'n dry but the factory paint is not very thick it was easy we just kept going to all the red was gone then i painted 4 coats of primer then blocked the car flat with 400 wet'n dry this car was painted in acrylic but a if you have 4 or 5 layers any no doubt it will be 2 pac paint i would'nt use paint stripper just in case you disturb some repairs on the car that its had done during its life i was lucky this car had not one repair on it but i did not use stripper on it i would go a heaver grit paper like 80 or 120 and then finish it of with 320 wet'n dry to get it smooth as a babys bum. Good luck its a big job mate ive just finished painting my new ser3 and i said to myself why am i doing this again there are no short cuts if you do them it will show just take your time and it will come out fine. Cheers Glenn.
