Page 3 of 7
Re: White Fc Convertible
Posted: Sat Feb 09, 2019 9:19 pm
by richrx
Thanks for the hints, so far nothing broken, but lots to go yet!!!
I'll maybe start ordering new clips just in case now though
Posted: Sun Mar 03, 2019 7:33 pm
by richrx
I don't even want to look at how long it's taken me to get the interior out this. But finally the carpets up. I've still got the wiring to remove but the initial parts done.
Very interested on thoughts regarding removing this bar to repair? I think ill need to strip the underside given the rust bleeding through...
Looks like a repair to firewall and both corners are rotten, possibly where water pools?
The repairs look like they'll be difficult to access and I'll need to remove a fair bit and drill out spotwelds to get to them( for an amature it's alot at least
) but I think I'm feeling positive that the floors solid!!
Oh I have also got a lockup now to store parts
Next will be engine, box subframe out and bumpers/wings off etc...
Posted: Sun Mar 03, 2019 7:41 pm
I wouldn't remove that floor crossmember Rich unless you absolutely have to... sure you could drill out the spot welds and fetch it out but you'll only have to plug weld it back in afterwards. If I was dealing with that rust around that item I'd clean as much rust back as possible with a wire wheel on an angle grinder then flood it with rust converter to kill the rest of the rust... afterwards wash it off and when dry give it a good coat of either zinc primer or POR15.... unless there are holes under it that I can't see in the photo
Posted: Sun Mar 03, 2019 8:42 pm
by richrx
Also does anyone known if repair panels are available? Sills etc?
Posted: Sun Mar 03, 2019 8:45 pm
by richrx
ian65 wrote: ↑Sun Mar 03, 2019 7:41 pm
I wouldn't remove that floor crossmember Rich unless you absolutely have to... sure you could drill out the spot welds and fetch it out but you'll only have to plug weld it back in afterwards. If I was detailing with that rust around that item I'd clean as much rust back as possible with a wire wheel on an angle grinder then floor it with rust converter to kill the rest of the rust... afterwards wash it off and when dry give it a good coat of either zinc primer or POR15.... unless there are holes under it that I can't see in the photo
Cheers Ian,
That's my gut instinct too. But I've seen it done so wasn't sure if that's the normal repair method. The last MOT hasn't shown up any holes in that area and I cant see any. It looks to be surface rust only.
I'm hoping the sills are ok too. They look solid but the bit towards the front may indicate inner sill issues too...
Posted: Sat Mar 09, 2019 11:18 am
by richrx
Posted: Sat Mar 09, 2019 12:50 pm
by danny
Well, you got yourself a project here! If it is possible for you, i would lift the body up, and roll the engine and box from underneath. Put the empty shell on higher stands, so it is easyer to get under it.BE SAFE! I should remove all the undercoating. There will be more surprises lurking...Just repair piece by piece and don't try to rush things. DO NOT set yourself a deadline! We are no T.V.-show! Wheeler Dealers, Car S.O.S., etc....done in two weeks??? I don't think so.
Posted: Sat Mar 09, 2019 11:36 pm
by richrx
Any hints how to get it higher? I've got a few old sleepers laying around I could put the axel stands on for an extra 10 inches or so. They seem secure and solid! I'll keep plugging away and removing parts untill I get to an unrepairable part
Does anyone know if any panels are still being made for these? Even in oz or stateside? Hopfully I've not asked that before
Posted: Sun Mar 10, 2019 12:27 pm
by danny
Hi Rich, I made my own stands long time ago. They clamp on to the sils with 2 M10 bolts. Hight is about 600mm. By bolting on in that way, te car is completely secure and doesn't wobble around. You can get in and under the car without any problem.
Posted: Sun Mar 10, 2019 5:01 pm
I’ve always pulled them out from the top.
Not difficult.
