I sort of have 2 threads in one here relating to this car..... the 13BT conversion and then a 12a engine swap to get me through this spring and summer.
My long term goal is to drop a S5 turbo II engine into this car but as this will take a year or two to prep and complete I wanted to continue to run my Elford engine for this year to get to some meets etc....
Sadly my engine had other ideas and blew up leaving the car unusable.
Keith then came up with a cunning plan which helped us both out. He'd got an Elford setup which he had never had the time to fit and the idea was that I'd borrow the engine out of his TWR RX7 which had a very strong engine in it and fit Keiths Elford stuff to it...
This was a win win situation.... I can borrow the engine until next winter and so get to use my RX7 for another spring/summer and Keith gets his engine converted to an Elford turbo and properly shook down so it can just drop straight back into his car and know it's sorted....... great idea
He pulled the engine out of his car....
and dropped it down to me along with a pile of Elford Turbo parts.
First job was to take the sump off and fit the Elford sump with an oil return for the turbo...
the 2 sumps were different....
the Elford sump came off an earlier engine and was in a pretty battered condition so I put the Elford oil return into the S3 sump I'd just taken off and refitted that.
Before refitting it I took the oil return off and cleaned it up....
then put it into the S3 sump, wire brushed the whole thing and gave it a heavy coat of satin black engine lacquer....
oh, and the engine mount as well.
Next day, I cleaned up for sealing surfaces on both the sump and the bottom of the engine with brake cleaner....
put a couple of beads of RTV silicone around it....
and bolted it back on.....also started fitting some more of the Elford stuff...
Next, I took my bonnet off for better access...
followed by the rad and fans....
then pulled my dead engine...
then lifted Keiths engine in...
and refitted the rad, fans and oil cooler lines...
To be continued...
