Searching through this forum I saw that Ian65 had recommended the SuperPro Poly bush so I've just ordered a set for £13.31 delivered off ebay (TDC Automotive). They should arrive later in the week so I can reassemble the idler and book the MOT!
KIMI 2 - 1983 Series 2
- Casey
 - Has thanked: 512 times
 - Been thanked: 455 times
Re: KIMI 2 - 1983 Series 2
KIMI 2's MOT is due shortly, so I thought I'd have a bit of a poke around before booking her in and found about 5mm of vertical play in the steering idler
 . I took the mounting bracket off and found a few pieces of disintegrated bush, but most had disappeared
- Casey
Whilst poking around, I also spotted the passenger side oil cooler bracket that mounts it below the radiator had failed. I decided the best option was to construct a new bracket. Works a treat!
New bracket and failed original:
- Casey
Waiting for SuperPro poly bushes to arrive for steering idler, so decided to clean up the bracket and give it the full POR15 treatment. A small thing, but very satisfying
I will use some superfine wet'n'dry paper to clean the bore of some slight surface rust just before greasing it it up.
 - Has thanked: 629 times
 - Been thanked: 222 times
Everything is looking pretty clean aye! I'm liking the calipers
 . Bigg Red are just across the road from me pretty much
						- Casey
Thanks guys, always more to do with these cars though
Polybushes arrived last week:
Now fitted, with fresh bracket fixing bolts/nuts:
That's improved the steering somewhat
Pleased also that all the "major/not nice" clunking/rattling noises have finally abated and she drives fine again now.
She's now booked in for her MoT next Tuesday - fingers crossed!
 - Been thanked: 188 times
Looks good, it will pass fine with all that nice new paintwork
- Casey
Gratuitous few pics - cleaned her to dazzle the MOT man and make sure she looks well looked after
The photos do flatter - the paintwork needs attention in a lot of places!
MoT is next Tuesday - not Monday as I stated above
