Page 5 of 7
Re: White Fc Convertible
Posted: Mon Jul 22, 2019 5:36 pm
by DKWW2000
Good work.....saving another vert is hard but you are winning
I changed my soft pipes, on my S5 Vert, not long ago.........they were fine but I wanted the braided (from Hel) for peace of mind, I had already covered them in shrink tube for safety. I have taken a couple of pictures of the stock pipes for your info if that helps:-
Posted: Mon Jul 22, 2019 10:56 pm
by richrx
DKWW2000 wrote: ↑Mon Jul 22, 2019 5:36 pm
Thanks, I'll need to look into new pipes. Is there any reason there not all braided ?
Certainly will be alot harder than I imagined buying it back unseen... I'm not going for concourse but just solid.. Clean and safe ..
Posted: Tue Jul 23, 2019 8:20 am
by DKWW2000
Posted: Thu Jul 25, 2019 9:40 am
by richrx
Ok so I'm pretty sure I've got all the parts off I need off. I have no excuses at all now but to get the Grinder out ... Scary times, a few more pics for interest since my writing isn't particularly interesting
Before the car goes back together I'll need to spend time derusting and replacing bushes etc...
I'm not sure on the condition of the wings, they look pretty rotten at the bottom..
And I'm still undecided on hydrate 80 vs bilit hamber rust removal gel for after the rusts been grinded off as much as possible....
Some pics
Posted: Sat Jul 27, 2019 2:55 pm
by A7RXY
Good luck Rich , you have some work to do there. It'll be worth it when finished and there will be times you will wish you never started, but I'm sure all will be good in the end.
Posted: Sat Jul 27, 2019 6:54 pm
it doesn't look too bad for a convertible... both of the verts I had were like sieves
Posted: Sun Jul 28, 2019 6:26 pm
by richrx
ian65 wrote: ↑Sat Jul 27, 2019 6:54 pm
I thought it looked horrendous at first.. But I don't know if I've been smoking something or just getting used to the holes but I'm sure it's getting more fixable the more I look at it ...
The wings look like I'll need to do some sore of repair...
Posted: Sun Jul 28, 2019 6:29 pm
by richrx
A7RXY wrote: ↑Sat Jul 27, 2019 2:55 pm
I hope not.. But my wife keeps telling everyone I've ruined it
so I already wish I had never started...
Posted: Thu Mar 05, 2020 7:29 am
by richrx
It's amazing how much work can be summed up with a couple of pictures. But I'm definitely at the stage where I can't really ignore having to cut out metal next
So in the following pictures I stripped the inner arches with a grinder back to.metal.
made up a home brew Billit Hamber detox mixture, treated the metal and rusted areas.
Cleared it off and re hit it with a grinder revealing more holes and covered the area with posphuric acid
So it has some protection now, just a quick coat of epoxy primer over the next few days if this weather holds
Posted: Thu Mar 05, 2020 7:32 am
by richrx
So my next thought is to drill the spot drills out of these tow bits of metal... See what lurks.
Can anyone advise if it's ment to be solid behind here?
And a close up of it helps
