marked wrote:Right so, Hello nice weather! Time to have another pop at my project..
I've replaced the starter and connected back up the main cable, however the similar other cable on the old starter was completely worn, and just fell to pieces when I tried to touch it.
It doesn't quite seem to fit though, I have removed the plastic part which shows the frayed wires (see pic) however it looks to me like this should actually be a sort of "in between" short piece which goes between this plastic clip and a "male" wire which plugs in to the smaller wire coming out of the starter? There is also another plug in the same area (not plugged in) which is black and yellow, any ideas what this is? or should be plugged in to?
http://imgur.com/9bW4Pio
Cheers!
ian65 wrote:the series 3 starter has 2 small wires plus the main heavy wire going to it
 I want to do as much as possible myself though, as I see that as part of the learning process.
