Unfortunately they are quite prone to cracking, mainly due to the force that placed on the bosses when removing the banjo bolts. If they crack again, I strongly recommend looking into an FC oil cooler. These having the fitting top and side to prevent this from occurring.
DWNUNDR wrote: ↑Wed Sep 05, 2018 6:05 pm
its 4 gauge.. more than enough...
4AWG wire usually has a current carrying limit of 60 to 100A (depending on who you believe).  While that is generally OK during normal engine running, current draw can spike well above that during cranking (200 to 250A).  Also, the fact that the wire is several metres long means you can experience voltage drop from the alternator even across 4 gauge. If you have an EFI system with fuel pumps, multiple injectors and a thermofan, you could easily exceed 60A under some conditions, which would push 4ga to its limit.
For these reasons, for the main battery positive cable, I was recommended to use 70mm stick welding cable or 00 automotive cable with a 250A breaker. After my 4ga starter wire melted, I upgraded from 4ga to this stuff, using a plated pass-through terminal on the chassis floor, and it was a million times better. 4ga wire is really only for big stereo amplifiers IMO.
Lots of great info on the topic here:
http://www.ausrotary.com/viewtopic.php?f=16&t=31504
