hi guys can i fit the turbo kit from the 12at to my std 12a?
mc turbo
hi ive found a turbo kit from a 12at savanna in good condition & ive been told it runs injection instead of the nikki carb on my S3, is it possible to fit the turbo kit to my 12a?? cheers
Re: hi guys can i fit the turbo kit from the 12at to my std
No
apart from the low comp rotors and an oil return, how is the 12at engine any different from the standard 12a Tool? Why wouldn't a 12at setup go onto it?
I guess retro-fitting the fuel injection system might be a massive pain in the bifkin?
Presumably there are whole shedload of sensors involved that wouldn't have been present, or even catered for with mounting points, on the carburetted setup
- Has thanked: 3 times
- Been thanked: 111 times
And the lack of injector holes in the housings
The injector holes are in the centre iron.Chud wrote:And the lack of injector holes in the housings
This is why you can't fit it.
Never even thought of the injectors, I guess cos I'm used to FDs that have primary and secondary fuel rails in the intake manifolds. I'd certainly be thinking of putting injectors there rather than trying to drill the irons. Although the more you think about it, the more bits a stock FB hasn't got to run injection... like you'd need an entire high-pressure fuel system and hi-volume pump as well... wastegate, extra exhaust plumbing, boost relief system... it'd definitely be a smeg's sight easier to upgrade the entire motor to a turbo version, like from a Series 5 or something. Hmmm, wonder if anyone's ever done itChud wrote:And the lack of injector holes in the housings
Yeah a couple of knob heads on here have done it.Lucky wrote:Never even thought of the injectors, I guess cos I'm used to FDs that have primary and secondary fuel rails in the intake manifolds. I'd certainly be thinking of putting injectors there rather than trying to drill the irons. Although the more you think about it, the more bits a stock FB hasn't got to run injection... like you'd need an entire high-pressure fuel system and hi-volume pump as well... wastegate, extra exhaust plumbing, boost relief system... it'd definitely be a smeg's sight easier to upgrade the entire motor to a turbo version, like from a Series 5 or something. Hmmm, wonder if anyone's ever done itChud wrote:And the lack of injector holes in the housings
'use the search'.....
