Since owning the fb there is a constant clicking/tapping coming from the fuel pump.
Is this normal on first gens or does it need replacing
fuel pump noise
Re: fuel pump noise
you should hear a slight hum/buzz from it when it's running but it certainly shouldn't be playing Dance With The Devil....... sounds like it's on it's way out
- Has thanked: 476 times
- Been thanked: 253 times
Re: fuel pump noise
Control your fuel lines and fuel pump if isolated from the chassis with rubber between fixing points.
Sound puls should be boost by the bodyshell works like a loudspeaker.
My english isn´t the best but read these link to understand what i mean. Hope i could help.
https://www.isma-isaac.be/past/conf/ism ... 0_0514.pdf
Re: fuel pump noise
Haha that did sound a bit gobbledygook lol but thanks for the link dudespirit r wrote:Control your fuel lines and fuel pump if isolated from the chassis with rubber between fixing points.
Re: fuel pump noise
Be worth direct wiring the pump using the original wiring to trigger a relay
I have a facet red top pump for sale which is a good upgrade to a 30 year old one!
You will need a fpr too though
95 FD RS in black
mc turbo
Re: fuel pump noise
hi mark ive just fitted a new facet red top is it ok without a fpr for now & doesn`t my S3 HAVE A OEM fpr? cheers mickmpk490p wrote:Be worth direct wiring the pump using the original wiring to trigger a relay
Re: fuel pump noise
Mick, the OEM fuel pump delivers fuel at at 3.7 to 4.7psi. The facer 'red top' delivers at 6 to 8psi. The use of a FPR would be useful in terms of not overwhelming your fuel delivery system.
