Taiga's 7
Posted: Tue Oct 21, 2014 6:33 pm
If you read my intro thread, then you know I bought this ugly pile for 600$. I went to the owners house only knowing that it will need to be painted and that there is something wrong with the engine. After talking to the dude for a while it turns out that it overheated. The previous owner already started the removal process for the engine and the wiring harness was everywhere! I even had a hard time tracking down the cables for the battery.
Anyways, the car turned out to be a 1985 gsl-se. Awesome!!!
The wheels are ugly and are "By BBS" and are 16", in my opinion that is a little large, I'm a fan of 15's. So they will eventually need to go! It also has some random blue lowering springs which dropped the car too low in the front causing the tires to rub on full lock. I'll probably end up buying Racing Beats lowering springs and use Tokico Illuminas.
This is when I first picked it up
The car is super dirty, I had pulled most the engine harness and started getting ready to pull it out. Dirty engine bay pic for reference.
One side all nice and clean.
At this point, nothing is holding the engine in aside from the sub frame and trans brace. Also all cleaned up.
Just a random picture
Picked these bad boys up. I will be doing the booster and Master swap as well. I'm going to do the 4 piston swap according to this guy's instructions. http://www.aaroncake.net/rx-7/4lug4potbrakes.htm
Front end torn apart. I still have a lot of sanding to do. Right now I'm focusing on getting it ready for paint before it gets too cold out. I chose a gloss black single stage from Space Age Paint and Body supply.
The race seat I had left over from my last project and the steering wheel and pedals I picked up from "Up Garage" when I was in Japan. The wheel is very rough, but for 5$ I couldn't expect any less. The dash is in piss poor condition, I literally ended up tearing the material off the dash. I might take it all off and leave it or cover it with some fabric. Or! I might just buy a new dash, who knows.
These just came in too! Excitement intensifies!
