Rear Speakers!
Posted: Tue Jan 20, 2015 3:20 pm
				Rear speakers guys......from memory they are 6" and 6.5" is standard speaker size but can they fit under the original plastic (allowing for the rear magnet)  One seems to be blown on mine and thought it would be good to update all four.  I know they're 4" in the front.
When installing I will mount them to thin MDF to give better sound as found in this AusRotary thread.
http://www.ausrotary.com/viewtopic.php?f=22&t=208400
EG....
For rears i prefer to go for a 6 1/2" 2 or 3 way or even split. in Stock location.
OPTION # 1
Factory location
I fitted Alpine type R splits and had to trim a little for them!
This is ok as there is plenty of space otherwise. Just not heaps of depth for a big magnet. Also the panel isn't very sealed, it vents into the rear behind the carpet...
You'll want to make a bit of a panel up to mount the speaker to the factory position. Go for some thin MDF like 3mm -5mm as your more just wanting a FLAT mounting surface to seal better against the speaker. Also use something to fill the little gaps in between MDF panel/spacer for better bass! I use sound deadener cut to size. Also fill holes on panel surface and deaden the entire panel if you have enough.
To fit 6x9's here is alot of cutting is involved and you still only have a 6" hole on the plastic trim. HARD WORK DON"T PUT EM HERE!
OPTION # 2
On the rear of the car where you have the carpet going around the little boot light..... You can mount 6x9"s there with a little bit of work.
I just marked out on the carpet and cut out 6x9 holes. Cut out panels to mount 6x9's onto. got some right angle brackets from bunnings and mounted panel vertically behind carpet into position. traced outhole for 6x9 and mounted speaker from the front through the carpet ... Looked like they were meant to be there and the extra room behind there helped with bass a little.
Things to remember
-Make panel go as far up, left,right, and to the floor as much as possible.
- I made 3 panels so looking from the top it was a bit like the letter C. The middle panel takes up the space under the boot light.
- Use AT LEAST 10mm or above to mount speakers.
- Use sound deadening around the panels to seal gaps against the metal frame. if sealed properly you get so much more bass and quality.
Has anyone done this or have any other suggestions? Thanks in advance!
EG....
OPTION # 1
Factory location
OPTION # 2
Things to remember
