Rear Discs
Has thanked: 156 times
Rear Discs
I'm looking for some rear discs and not having a lot of luck, if I remember the RX7 and 626/ Montrose used the same axle but 110 pcd and mine is 114, does anyone know if the 323 from say 91 used the same discs as the RX7
Or know of any for sale in the UK.
DeanRX7
Has thanked: 39 times
Been thanked: 63 times
Re: Rear Discs
Post by DeanRX7 »
Have some spare fronts! New in box.
Re: Rear Discs
Thanks Dean, I've already got those it's the rears I'm finding hard to source.
Re: Rear Discs
EBC or rock auto!
Re: Rear Discs
Am still searching. A lot of incorrect info out there on databases
These are the important numbers ....
Fitting Position:
Rear Axle
Diameter [mm]:
257
Brake Disc Type:
Vented
Number of Bores:
4
Bolt Hole Circle Ø [mm]:
66
Brake Disc Thickness [mm]:
20
Minimum thickness [mm]:
18
Brake System:
AKEBONO
Height [mm]:
63
Re: Rear Discs
Can’t you get them skimmed Dibs? I had mine done and they came out like new
Re: Rear Discs
I think Rockauto has the best price ex US.
2x Centric rotors shipped for £55.67 (excluding HMRC running interference) th:
Re: Rear Discs
Dave I chk'd Rock but the rears they show dims for are 110 PCS, I was hoping to get some in the UK.
Ian, getting them skimmed I think is the way to go.
I'm still having trouble with a few of the bolts on the bushes, waiting for tools to be delivered. I thought I had most tools but the access to some is by ring spanner only, I'll get there in the end still have left.
Re: Rear Discs
Dibs. When you get to the Rockauto menu
Choose Mazda - 1985 - Rx-7 - 1.3
It's the GSL-SE items that you want
The Centric part number is 12145013
You can cross reference that to double check
The pcd is correct. 4x114.3
marksport
Has thanked: 13 times
Been thanked: 97 times
Re: Rear Discs
Post by marksport »
In stock in the UK at ebc...
Need to go back to work. This lock down is boring me :lol:
