FC Calipers on S3 Discs & Hubs
BO0557
Re: FC Calipers on S3 Discs & Hubs
Post by BO0557 »
I do have a set of the RE Speed brackets that i bought years ago..
Alls you need then is FC hubs and FC disc if you thinking of going that way.. Worse case if you want to keep 4 stud - get some GSLE front hubs which are 4x114 and get some 15" wheels in 4 stud :)
Has thanked: 5 times
Been thanked: 23 times
Post by DB RX63 »
OK Chaps,
So has anyone got a pair of FC hubs and s/h discs that I can play with ?
Post by DB RX63 »
Some old FC pads would be handy too......
BO0557
Post by BO0557 »
ive got the old front discs of mine - still in very good condition i was actually going to throw them out this weekend but if you want them they are yours..
Post by DB RX63 »
Cheers Damon, keep hold of em, I'll pick em up at some point.
Has thanked: 473 times
I know the thread is old but I want to know if this part is working with the Rx7 FB 4x114,3mm Watanabe wheel 8,5x16 ET-6mm + FC/FD RX7 BRAKE CALIPER
http://www.ebay.com/itm/AE86-FRONT-BIG- ... cb&vxp=mtr
I doubt it will fit the RX7 strut.
You can buy these from REsoeed in the States but Billy doesn't seem to work there now and the service is terrible I've heard.
I've got the dimensions/drawings for making these to suit RX2/RX3 and you can modify to suit your strut. Any good?
TOOL wrote:I doubt it will fit the RX7 strut.
What do you think about these: http://trsmotorsport.com/index.php?opti ... &Itemid=26
theracingstore.pdf
(606.57 KiB) Downloaded 485 times
I think they're expensive.
Discs are plentiful. Calipers are easily available second hand too and you can buy rebuild kits.
The only part you really need is the bracket.
RESpeed used to do brackets for S3 RX7. Try and track some down on RX7club.com
TOOL wrote:I think they're expensive.
Respeed 199$ only 4 parts
Theracingstore: 625$ all inclusive parts
Billet Aluminum Four Piston Calipers
Billet Aluminum Hubs with screw in dust caps
Billet Aluminum Mounting Brackets
10 1/4 Diameter 5/16 Thick Drilled Rotors
Grade 8 Hardware
1/2 x 3" long screw in wheel studs
Wheel Bearings
Grease seals
Hawk Performance Brake Pads
Meets All NHRA / IHRA Requirements
