Okay this hasn't been updated since I originally bought the car. Progress has been slow as its my first car in England, so I've had to buy tools and stuff. Kept going to do a job on the car then realised I needed to buy some other item to finish it haha.
Firstly I just cleaned the engine bay up a bit by removing all the muck off the paint. It was caked on over all the paint inside the bay. Gave the radiator top cover a quick spray. Replaced all the coolant hose clamps also. Small things make a good difference! Should really wipe that radiator shroud down though
Clean enough - Check the top of the passenger strut!
Had to replace my intake manifold gasket as it was dripping coolant onto the exhaust. It was covered in loads horrible crap that I scraped off and cleaned up. Don't have a clue what it was? I put in some core plugs too.
Mostly cleaned up
Also had to replace these o rings. Easy as to do. Hardest thing was getting the hoses off
. Ran clean water through it and shook it about to try clean out the inside too.
Done a bunch of other smaller bits and pieces and finally booked and MOT and passed first time!
Although I had a few advisories.
Looks like I'm going to need a new exhaust. Sort my handbrake out. Needa figure out if I should buy new discs or just them them skimmed also. For the ball joint, should I just replace that? Or would it be worth buying new track rods?
I think that's all for now. Thanks for reading!
Jesse
