bought a set of 35mm PI lowring springs very dissapointed
Re: bought a set of 35mm PI lowring springs very dissapointe
hi biz did u change the rear shocks as well? otherwise it could b ur old shocks r worn? mine seem fine it was just the small drop in height I was disappointed with, but ive got a full set of gaz coilovers to fit so it should b much better
The shocks were replaced with adjustable ones front and rear, both on the softest setting at the moment. Koni yellows in the front and KYB AGX in the rear. I know the ride should be much harder with the increased spring rate and dampening but the here is a noticeable difference between front and rear which leads me to think there is something wrong. I'll check the top mounts and Bumpstop clearance this afternoon and report back.
Cut about 15mm from the bumps tops and the problem seems to have been solved now
