Lucky's Series 3
Re: Lucky's Series 3
ian65 wrote:
Lucky wrote:Can't really run vacc advance as the carb doesn't support it.
can't you tap it off the manifold?
The IDA setup doesn't draw enough vacuum to make it work. Just add 5 degrees to base timing.
OMP doesn't need a linkage. Just fix it about halfway open if you want to run it. That's how my 12A ran.
So, some sensible pics then? Still a few tidying up and finishing off bits to get done but hopefully the end is in sight (at last!). I have to say, I'm actually getting a bit excited about it all now...
Paint is done, bar final titivating;
(oil cooler now straight, lol). Not that you'll see it really once my home-made new improved grille is in place. Moar of that another time
Think I'll let the shop stick the number plate back on, though as every time I do it, it ends up on the piss no matter how carefully I measure and mask up
Bit of running in... handy things, dynos
My renovated brake calipers in place;
All the bushings are done (thousand thanks to the long-suffering Chris at Super 7). It was as horrendous a job as you'd expect, several of the old ones needed burning out! Fire! Cleanse them with fire!
Turns out the wheel being pushed back in the arch in the crash wasn't actually down to any bent arms. Mazda built these things tough, apparently. In actual factual, the washer retaining the control arm bush had proved tougher than the manky old bush and they'd both been pulled through the eye :shock: That's the kind of forces involved when you find a Corsa inconveniently wedged in your wheelarch :roll: The good news is the new bushes and washers have sorted that so no new suspension architecture was needed. Chris rates the Energy Suspension kit quite highly, especially as the really tricky ones are two or even three-piece to ease insertion... although he did say the grease was horrendous and he basically had to wire-brush it off his skin! :? Never been so glad not to do a job on the car myself, lol
OMG! Dat rad! :o
This is something I've never encountered before... and I'm betting many of youse guys haven't either... that of buying something in the aftermarket that is actually too good for its purpose :shock: The radiator not only fits (and to quote Jason) "the best fit of any aftermarket radiator I've ever fitted to any car, ever" but it also works so well that the car was struggling to get up to temperature! This necessitated the making-up of a shroud to cover the back of it, leaving only the fan aperture uncovered. At first the thinking was we could fabricate some flaps to uncover part of the shroud if needed but in actual fact it looks like they won't be! Reckon with hindsight I'd have easily got away with the thinner rad, but at the time I guess influenced by the struggles of cooling an FD, I figured "hey, you can never have too much cooling on a rotary....can you?". Turns out you can. But at least it's easily managed, and it's a nice problem to have for a change
Some nice little bits of fab work from the Super 7 guys, like this nifty little throttle linkage bracket and suchlike. There might be another version for the final iteration, just to aleviate the slight bending of the OE bracket!
The mesh filters will be going in favour of a K&N box filter. This is a bit of a shame, as I love the look of the trumpets and clean-ness they lend the bay, but the K&N will just give a little bit of a calm airbox effect to aid starting, which is currently a bit of an annoyance. J's looking at fooling the vac advance system via some electronic trickery that goes way over my head, but sounds plausibly from what little I did understand. But he (and Al the bodyshop dude who's a bit of an old-skool carb wizard on the side) persuaded me to go for better filtration anyway and having seen how little the mesh teastrainers actually filter out, I have to say they're probably right. Shame, but at least I'll have another big shiny thing to polish now. So that's really that. Here is an couple of photos of how the bay looks currently. It'll probably have changed completely (again) by the time it ever sees the light of day :roll:
shiny strut brace is shiny!
and just for Jesse, one last arty one to finish off :lol:
The tyre-wall-black fairy needs to visit then it looks just about good to go Nik.
Has thanked: 441 times
Been thanked: 181 times
Lucky wrote:and just for Jesse, one last arty one to finish off :lol:
Thanks for thinking of me, Nik! :lol:
Nearly time for a wash aye bro th:. Can the bushes really be that much of a pain to get out? Would a shop that has a press not let you bring in the arms for a bit of beer money? :?
Radiator is looking awesome! I reckon it seems like a pretty good price to pay for what you got aye. :)
Trace is looking sexy.. Along with everything else :lol: Nice work to you and the guys who have been working on her h:
re japi
Post by re japi »
Looking very good. Good job :)
Has thanked: 300 times
Been thanked: 146 times
Looking all very cool there Nik. I'd quite like to try one of those rads (but mine's not broke yet so maybe for later). I will say though, Volvo 940 / 960 radiator had a flap arrangement built into the shroud (and it fits a FB too) I spoke to a guy who runs one.
Annoyingly, I could not find a pic of a 900 series item. However, here is a shroud from a c70 which shows what I'm banging on about :roll:
Jesse. Yes, the bushes can be a whole bunch of pain to get out. Andy Tappenden at AMT had to cut most of mine out!
Codge, are you not advocating the application of a red coach stripe on this occasion?
Been thanked: 111 times
Post by Chud »
Would you be so kind as to link me to the company that sells that radiator?
Looking terribly pant stirring at the moment dude, good job I'm stood in a swimming pool. (An otherwise empty one for those getting concerned for public safety. )
Keep it up.
When is dyno run proper?
Has thanked: 18 times
Been thanked: 47 times
th:
Doesn't the thermostat keep the engine at temperature, or am I being thick?
Lol^^ apparently not :?
Dave, that Volvon flap thing is pretty much what we were going to do only in alloy. But it looks like it might not be needed. Basically they're just light-hinged flaps that air pressure through the rad forces open as you move. If the fan comes on the negative pressure differential sucks the flaps shut and forces all the air to be drawn through the fan. Like all the best things in life, simple yet clever. Those funky Swedes, eh
Timmers, got to run it in first! Although after the last time I ran my FD in like Miss Daisy and it blew up anyway, the next time I "ran it in" like I stole it and it seemed to like that :lol:
Link to Auction here; http://www.ebay.co.uk/itm/201067319634
Like I said, with hindsight I could have got the 2-row version but with your turbo motor the three will probably be better anyway? Great company to deal with, too, aleviated all my worries about shipping something so delicate from the USA
