I bought my car some years ago and was supposed to have been already restored. At the final end it was proved that it was a very poor restoration.
I firstly attach pictures of how it looked.
It looks O.K., doesn't it? but underneath the rust was working.
First it was a small bump that was developed in the top of rear-right collumn and underneath the rear fenders and the rear bumper (Not visible in these photos).
I finally decided to to a proper body restoration.
Photos and description of the procedure will follow
Body restoration history of my 1980 RX7
- Anoiksi2011 125.JPG (1.04 MiB) Viewed 7108 times
- Anoiksi2011 123.JPG (1.23 MiB) Viewed 7108 times
Re: Body restoration history of my 1980 RX7
After being stripped and bumpers and rear window removed the size of dammage was gradually revealed.
- Unferneath the fenders
- PICT0049.JPG (1.38 MiB) Viewed 7105 times
- After rear window removal and some paint removal - what a surprise! Rust underneath the window and in the basis of the rear right column
- PICT0048.JPG (1.36 MiB) Viewed 7105 times
- Underneath the bumper (rust, rust rust)
- PICT0045.JPG (1.08 MiB) Viewed 7105 times
Apparently, the corrosion was mainly focused on the top and on the base of the right rear column.
- The base of the rear right column after removing the rust and restoring
- PICT0113small.jpg (81.35 KiB) Viewed 7085 times
- The rust in the ceeling (where the small bump in the top of rear-right collumn was visible) was so expanded. You can reckon that from the hole that was created. (You can also see the new metal patch).
- PICT0114small.jpg (79.63 KiB) Viewed 7085 times
Rear fenders had extensive corrosion. Even part of the rear left fender had to be totaly removed and replaced by new metal
- PICT0064small.jpg (76.72 KiB) Viewed 7085 times
- PICT0063small.jpg (56.53 KiB) Viewed 7085 times
- PICT0055small.jpg (78.94 KiB) Viewed 7085 times
Wheel arches and rear bump area after treatment
- PICT0065small.jpg (75.3 KiB) Viewed 7084 times
- Wheel arches had to be restored (they were quite rusty)
- PICT0061small.jpg (86.21 KiB) Viewed 7084 times
- Underneath the bumper after treatment
- PICT0057small.jpg (81.3 KiB) Viewed 7084 times
The car was finally fully striped to examine potential rust damages
- Luckily, the windscreen area was rustfree.
- PICT0157small.jpg (67.58 KiB) Viewed 7083 times
- Passengers door ( the right one - we are in Greece remember?) revealed. At some stage of its life was red! (obviously obtained from another RX-7 SA car) The original one rests in peace (or in rust should I say?)
- PICT0156small.jpg (46.65 KiB) Viewed 7083 times
- General view
- PICT0155small.jpg (84.22 KiB) Viewed 7083 times
We've said on here for a long time that these cars hide their problems under a beautiful top body.
They hide rust very well indeed.
Thanks for sharing pics.
its when i see a shiney fb and get told no rust etc that makes me think of this.
you do not know anything till you literally go right back to bare metal and with the fb being 30 years old on average
then there is going to be rust somewhere unless documented proof of grease/oil being pumped everywhere from the
day it rolled out of the factory.
so i have to sometimes stop and think is it better to spend about £1000 or so on a car you can strip down to its shell
and put in one of those baths that removes the paint, any filler and rusted parts and then cut out and professionally
weld up the 'holes' then put all back together, lot of money/work but then you'd know what condition the body was in.
i know of a mint fb for a few grand but i just wonder where that rust if indeed there is any, lurks.
The whell arches were sprayed
- PICT0158 -small.jpg (79.26 KiB) Viewed 7057 times
Car ready to go for the paint-job
- PICT034small.jpg (70.86 KiB) Viewed 7057 times
- PICT038small.jpg (85.59 KiB) Viewed 7057 times
- PICT043small.jpg (81.52 KiB) Viewed 7057 times
