Brakes upgrade or standard?
Hi there, I need new rotors for my 1983 model. Has anyone ever fitted aftermarket discs and calipers? (Brembo, woodward) links to what makes would be nice! Or should I play it safe with new standard parts? Thanks again for your help Dave!
- MelloYello
- Has thanked: 22 times
- Been thanked: 52 times
Re: Brakes upgrade or standard?
Unless you are going for top performance track requirement, then stick with stock.
If you have everything working as it should the stock brakes are perfectly capable.
- Has thanked: 473 times
- Been thanked: 253 times
http://www.racingbeat.com/RX7-1975-1985 ... Discs.htmlBoggy2112 wrote:Hi there, I need new rotors for my 1983 model. Has anyone ever fitted aftermarket discs and calipers? (Brembo, woodward) links to what makes would be nice! Or should I play it safe with new standard parts? Thanks again for your help Dave!
yepMelloYello wrote:Unless you are going for top performance track requirement, then stick with stock.
13B Turbo streetport with the opportunity to take it on the track
I am asking me why Mazda was making 3 brake upgrades from S2 1983 for the Rx7 turbo II to get it streetable.
It cannot be only for compensate the more weight.
Check this stuff out.
http://www.msfracingcomponents.com.au/m ... omponents/
FC 4 pot front brakes are the usual upgrade.
YepBoggy2112 wrote: I would like to fix the car up, and drop a 13b turbo Street port engine in it. I would not be racing it, but I would like to have the opportunity to take it on the track!
