Blast it!
Got any useful hints or tips on restoring our cars or the parts for it? Please share them here. General stuff only.... please put item specific info in the categories above
Blast it!
So i bought this from the restoration show a couple of weeks ago..... wanted one for years and finally got around to getting one.
I'm currently using crush glass blast media which is great on rusty parts but a bit severe for alloy..... it will probably calm down a bit once it's done a few cycles through the gun and broken down a bit but I want something a with a lighter touch to do my inlet manifolds....
Anyone else got a blast cabinet and what blast media do you use and for what? Any handy hints?
Re: Blast it!
OOOoooohhhh fancy. Seems like one of those things that would be very satisfying to use.
I have had no experience but I have read that ground walnut shell made a good media to use.
Has thanked: 628 times
Been thanked: 218 times
Re: Blast it!
I've always wanted one of these. I checked them out at the NEC Classic show last week. We have a good one at work but unsure if I'll be allowed to use it for my own stuff hahaha. Got any pics of before/after blasting?
Has thanked: 505 times
Been thanked: 451 times
Re: Blast it!
Ooooooooooooooh, nice - I can't help with your query Ian, but I keep looking at getting one of those. Be very interested to see how you get on with blasting an alloy piece.
kenwhiteside
Has thanked: 2 times
Been thanked: 21 times
Re: Blast it!
Post by kenwhiteside »
Bead blasted the alloy inlet manifolds on the elford then clear coated with high temp clear. Still looks good 2 years later.
Re: Blast it!
kenwhiteside wrote:Bead blasted the alloy inlet manifolds on the elford then clear coated with high temp clear. Still looks good 2 years later.
did you use glass bead or plastic?
kenwhiteside
Re: Blast it!
Glass beads I think. Gave a nice finish.
Has thanked: 5 times
Been thanked: 23 times
Re: Blast it!
Post by DB RX63 »
I've heard that some companies use crushed walnut shells where they don't want to damage items, also some form of soda is sometimes used which is softer.
I used these guy's for my car, but surprised to just see that they have ceased trading.
http://www.blast-cleaning.co.uk/index.p ... rticleid=8
Re: Blast it!
Couldn't resist a "VAT Free" voucher offer at Machine Mart and just lugged home a Clarke version of that cabinet. Might be a while before I can set it up fully, but I already have a bench full of rusty parts that need attention and doing it with wire wheels, etc, was getting to be a chore!
Re: Blast it!
DB RX63 wrote: Tue Nov 21, 2017 8:31 pm I've heard that some companies use crushed walnut shells where they don't want to damage items, also some form of soda is sometimes used which is softer.
walnut shells are used for rumble polishing, I'd have thought a bit soft for blasting.
Return to “Restoration - Tips and Techniques”
