Rear Window Strut - Strongarm
Been thanked: 187 times
Rear window strut (non electrical connection side)...... can bring to RR
£18
Re: Rear Window Strut - Strongarm
I'll have that Pete if nobody else has beat me to it,
Thanks Keith, will bring with on Sunday :thumbup:
Good things those. Just fitting one side is surprisingly effective :thumbup:
rotarypower
Has thanked: 94 times
Been thanked: 71 times
Post by rotarypower »
Does anyone know the part number I require to replace both of my hatch struts? And a good supplier?
I'm fed up of having to carry a piece of wood around in the boot! :thumbup:
Select the strongarm option from the drop down.
https://www.rockauto.com/en/catalog/maz ... pport,1404
One is actually sufficient if you don't want to mess with replacing the electrics on the other side. They do come with instructions as to how it;s done though. It involves cutting the ols strut to remove the switch components and placing those on the new strut. Then heat shrink or tape the wiring to the strut body.
Return to “Parts For Sale”
