New Springs - Racing BEAT
Been thanked: 187 times
Re: New Springs - Racing BEAT
Front Springs all fitted now:-
For you Thomas:-
The rear will not be as easy :roll:
Has thanked: 156 times
You don't hang about Pete .... mine are still in the box .... I want to do my rears first so can you get a move on ....
Has thanked: 473 times
DKWW2000 wrote: Fri Apr 24, 2020 8:35 pm For you Thomas
Pete i take heat resistant graphite grease in the wheel bearings with very good results since more then 200 000 km.
spirit r wrote: Fri Apr 24, 2020 10:34 pm
Thomas .....I use a special additive in the Bearings........you can see the Yellow & White (Gelb und Weiss) splatter on wheel arch, comes in special containers :o
"Yellow" your bearings will corroded more quick then ? I only can see the standard red grease in your bearings and the rest of the old gold spray can you've smeared everywhere..?.... -haha-
My mystic grease help with the extremly wheel set up dishes -6mm on my car. :lol:
spirit r wrote: Sat Apr 25, 2020 4:18 pm "Yellow" your bearings will corroded more quick then ? I only can see the standard red grease in your bearings and the rest of the old gold spray can you've smeared everywhere..?.... -haha-
My mystic grease help with the extremely wheel set up dishes -6mm on my car. :lol:
Gotcha Thomas............My "Mystic Grease" yay yay
Senf und Mayo
You're the strut king now Pete!
I now have the rear prepped for new springs, have changed the ARB Links & the bushes with Energy Suspension, I bought a job lot of 10 a while back & forgot so if anyone needs some give me a shout:-
Haynes says to remove the springs you should disconnect all the suspension links & both shocks to both wheels & lower with a jack on the diff (with car supported on chassis both side) :o
I had a think & decided to just disconnect both shocks & ARB Drop links & with the assistance of a scissor jack under disc adjust the tilt of the vehicle with a 2 Ton under the diff (also supported under chassis).
I then, with the aid of 2 cut down spring compressors removed the spring having first undone the 14mm bolt in the centre of the rubber bump stop
Now just have to await (been 6 weeks so far, from AUS) the arrival of new Rubber Spring Insulators.
After nearly 8 weeks the the Spring rubber Insulators finally arrived:-
Springs went in easy as they are slightly shorter (approx 1")
All put back together, car sits about the same height as before but what a difference in handling s(c) (had to go & get some essential supplies Officer) sya :oops:
The stance seems different even though the ride height (2 fingers between tyre & arch) remain the same :?:
Great work Pete, how the ride then? Is it much stiffer than before?
