Has thanked: 441 times
Been thanked: 181 times
That's an impressive underside there! That gasket is lovely :shock:
Has thanked: 365 times
Been thanked: 165 times
I know the different between lhd cockpit vs rhd cockpit. Perhaps you got the inspiration save some power consumption to protect your light switch and get more brightness. I am very happy with the results and easy mod also.
20210112_172324_001.mp4
(43.3 MiB) Downloaded 432 times
LED
OEM
That looks so clear aye! :o I had been thinking about doing this as my cluster is out atm. Does the dimmer still work?
Hobbawobba wrote: Thu Jan 14, 2021 7:39 pm That looks so clear aye! :o I had been thinking about doing this as my cluster is out atm. Does the dimmer still work?
The dimmer works perfekt and the two green indikator lamps shining very bright.in LED.
20210115_182006.mp4
(8.26 MiB) Downloaded 430 times
Awesome. I might get to buying some LED's then! Hahaha
Paid my duty in the custom inspection get the mazdatrix parts i am ordered 05.12.2020 today. So corona lock down will b more easy next weekend for me :lol:
Has thanked: 300 times
Been thanked: 146 times
Much love for shiny new parts Thomas. :thumbup:
Always great to get boxes of new parts.... they will keep you busy for a while Thomas th:
Good haul there, bro! Some very nice bits in there I see. I have one of those watts link braces aye. Peace of mind knowing it's installed :thumbup:
Its important to protect the car inside from gases,smoke and smell. My wife dislikes the castrol smell inside of the rx7. I found out that the 3 old shifter rubber seals are broken. Mazdatrix offers a short shifter set i dislike. Mazda invastigated a lot ingeneering in smoth shifting and i didn't want to change this. Short shifter works to strong for me.I drilled out the rubber and glued the parts together after I exchanged the rubber seal. The rubber glue "sikaflex 221 black" works like the mazda glue and there isnt any vibration on the shifter stick.
Some pictures on the left side the old broken parts on the right side the new mazdatrix rubber seal and blue distance ring.
