A couple of queries seeing as the instructions are not very thorough.
The kit includes a check valve to be Teed into the existing fuel line paralel to the new pump......I have no idea what this achieves..is it needed?? in the past any electric pump like this used simply has the tank pick up in and carb feed out! My only thought is if it is set to allow back flow if the system overpressures and act like a fuel return.
The drawing shows the pump mounted vertically, it is a chunky high pump and would be better horizontal. Nothing is mentioned about mounting angle/position.
Finally, I hear the push on connecters supplied are not very good.....looking at the brass poles they could be threaded with a die for nuts and ring terminals....anyone tried? I dont want to twist the terminal and break it inside the pump.
