KIMI 3 - 1984 Series 3
Has thanked: 443 times
Been thanked: 324 times
Re: KIMI 3 - 1984 Series 3
Cleaning and refreshing parts to go back on continues. I'm also treating some surface rust on the bodywork, only accessible with the tank out. Luckily there is not much there, so better to sort it now.
Progress so far:
Dibs' NOS tank with a spray of Hammerite satin. New sender, new hoses, new screws. new jubilee clamps.
Most of the remaining bits. Most metal parts have been painted with POR-15:
Has thanked: 127 times
Been thanked: 39 times
Well Malcolm it certainly looks better there than it did in my parts store .... Nice work.
It was looking very tired, with some surface rust evident to the rear of the fuel tank.
So, a full POR-15 prep treatment and 2 coats of POR-15. I would have liked to have done more (like the axle!) but I know from experience how "job creep" extends the time off the road! This started as a simple, tank out, replace fuel sender, put tank back in. It has already extended well beyond that!
Fuel pump assembly fitted back, just the linking pipework to re-connect.
I changed the diff oil while convenient, with the car up and tank out of the way. The old oil came out very clean; a distinct, red, transparent colour. Odd though, nearly 2 litres drained out, but the manual states capacity is 1.2 litres? I put in about 1.2-1.3 litres of fresh oil and that came to the fill-plug level.
The drain plug had a few fine metal filings attached, but nothing much. Nicely cleaned up - oh, the simple things :)
Lying on your back, applying POR-15 is a hazardous business, full PPE required :lol:
You don't want to be breathing in the fumes from that, or get in in your hair or skin. Despite precautions, some paint managed to drip down my right wrist without me noticing, so I'll be wearing that for a week or two!
Finally finished fitting the tank back and ready for a run out!
Pics along the way:
I've just been out to fill the tank - not to the brim but where I judged to be between 3/4 and full.
Gauge read 7/8 - yippee, no more guesswork :lol:
I drove the car around, did some heavy braking and acceleration, sharp turns, etc. Parked up and no signs of any leaks so all looks good.
I'm planning on attending the Bromley Pageant this coming Sunday (https://www.bromleypageant.com/). Clive on the MRC arranged a stand, so he'll be there with his RX-4, plus Philip, another member, with his RX-3, just the 3 of us I think. I got a stand ticket just before they closed the window. Looks to be a very big event - the show has been going for over 40 years!
If anyone is nearby and at a loose end on Sunday, pop along and say hello :thumbup:
I've just realised, it's exactly 4 years ago today that I bought KIMI 3 - Happy Birthday :D
Great to have a reliable fuel gauge again :thumbup:
I checked the "failed" sender and, like the sender on KIMI 1, the earth connection from the sender plate to the connector pin is open circuit. An easy fix and I'll then have a spare sender. The ohm readings on full and empty tank are within spec.
