Cadfael wrote: ↑Thu Feb 08, 2024 3:34 pm
As I understood it, the main cause for the binding is the fact that the upper links are not parallel with the lowers, exacerbated by the different lengths. The heim joint uppers use tabs welded on to the outside of the stock attachment point on the car's body to make the upper links parallel whilst keeping them in double shear. When I was looking at the forums a couple of years back, seeing the complaints about the FB's rear suspension geometry immediately made me run to parallel links as the answer. Once I've got the cars back, I might jack them both up and test the rear axle's limits of articulation without forcing them, to see if the heim joints have made it better or worse.
The binding is mainly caused from the difference in length and how wide set the upper arms are. The fact that they point inwards somewhat helps reduce the bind, but by moving the upper arms outwards at the body end and fitting heim joints will make the binding problem worse. Ron sutton has published some good guides about how to set up a solid/live axle with 3 and 4 trailing links. Also read Jim Susko's book on getting the RX-7 FB to handle.
For a 4 link car, you want the lower links wide set in the car, the wider the more control there is over the axle. The top links can be on top of the lower links, or wider or narrower, but the wider the top links are set, the more issues with bind you have. The narrower the top links, the more articulation / less bind you have in roll. The best set up is a 3 link, much more articulation before things bind. That's why you see 3 links so much in handling cars, and 4 links in drag cars. 4 links are stronger for hard launches, 3 links bind less. The trouble with a 3 link is packaging.
I don't mean to come across as harsh, hopefully you like how your car drives, but unfortunately you have set up your rear end to bind not move, you need to narrow the top links not widen them, and give them very soft bushings, not heim joints. If I've understood you also have stuck with rubber bushes in the lower links also. This all seems like the opposite of what needs to be done, and the opposite of how people have been setting these cars up for the street, AutoX, racing in SCCA and elsewhere for decades, but seems to be how T3 sells their parts. Also mounting the upper link in the wheel arch reduces clearance to run a wide tyre on the rear.
I don't recommend Heim joints/rod ends on a street car, but if you have a track car and want rod ends, you should fit rod ends everywhere except the upper links, which should be soft rubber bushes. It's a good idea to do split pins but nylocs or two nuts locked together should be fine to run the upper link inner bush loose, or use a poly bush like energy suspension, which isn't a bonded bush and works better from this point of view, but I would prefer softer for the upper arms.
The watts linkage could use rod ends over rubber bushes even on a street car as the watts (or panhard) doesn't transmit load through the suspension in steady state road driving like the trailing links, so wouldn't be making noise and harshness as much as rod ends in the trailing links. I had rubber bushes in the lower arms and rod ends on my panhard bar at first, and it was reasonably quiet for the road, and it was a much more noticeable increase in noise and harshness when I fitted rod ends to the lower arms compared to having rod ends on just the panhard. There is a watts linkage brace available from mazdatrix to put the studs in double shear too.
The stock watts linkage is fine on a road car, but I personally don't like it that much, and by the time you've made arms adjustable and rod ends, and fitted a brace, you may as well put the effort into ditching it for a panhard. The stock watts link is a lesson in how to screw up a watts link as much as possible. The advantage of a watts linkage is better lateral location of the axle, compared with a panhard rod, but in a factory set up with rubber bushes, the better location is not worth it as you don't have accurate lateral location with the flex in the rubber bushes, so all mazda did was add weight, complexity and cost over a panhard. Then to make it worse, they put the pivot point on the axle not the body, making the roll centre migration and sprung weight worse, they mounted it high on the axle, giving a high rear roll centre, which gives oversteer, and for those of us that lower these cars, the rear roll centre doesn't get lower as you lower the car, but the front end gets drastically lower, so a lowered car has a steeply inclined roll axis, giving much worse oversteer (panhard and roll centre correctors are needed). Then they offset the pivot point to the right (they had to as the watts is ahead of the axle not behind) which means the rear roll centre is not in the centre of the car, giving asymetric handling as the car rolls, which is the only advantage a watts linkage has over a panhard, so the mazda watts link has no advantage over a panhard, but a lot of drawbacks. Panhard rod is light, simple to fabricate, easy to adjust and easy to get a low roll centre. The neighsayers that think a watts is better, its been proven in tests with professional drivers in well set up cars that most drivers cannot tell which way round the panhard is laid out, so the small asymetric difference in roll on left and right corners is not as big of a deal as people like to think, and is a much better compromise than most watts linkages.
When you've realised the t3 set up doesn't articulate, the best way to fix this is to do a 3 link. The 3 link is fairly straight forward to install, not much fabrication at all. Unfortunately G force engineering who used to sell kits is long gone, but I believe KC raceware still makes similar kits. They wouldn't be that hard to replicate if you could do some fabrication. They also sell a proper Panhard bar (not like T3 which is awful), the panhard is a bit more effort to install but still not much at all.
If you don't want to go to a 3 link and panhard bar, and want to try and fix the 4 link, then you wont be able to run the car as low, and you'll need to cut off the upper arm mounts from the axle, and re make the brackets, moving them inboard, and mounting the arm as far back behind the axle as you can to make the upper links as close in length as you can to the lower links. It'll still bind but a bit less than the wide set upper links you have now.
Take a look at my build thread I have a 3 link and panhard on my race car.
