Carb Rebuild Kit
stid90
Carb Rebuild Kit
Post by stid90 »
Does anyone know where I can get a carb rebuild kit in the UK or is it an import from the states only?
Re: Carb Rebuild Kit
I think I bought the last ones in the UK and took them to Belgium.
Just watch out on the seats as they may be different thread.
What's wrong with your carb?
stid90
Post by stid90 »
I was getting flooding in the carb. I thought it might be the air jets getting clogged up so was thinking I would have a look and change the gaskets etc.
Take the top off carefully and take a look. I've found they quite often come apart without wrecking the top cover gasket.
stid90
Post by stid90 »
I took the whole carb off but I've given the unit a clean and the gasket is already looking cracked and corroded from the edges. I might just take the hit and import one.
