I'll maybe start ordering new clips just in case now though
Rich
ian65 wrote: ↑Sun Mar 03, 2019 7:41 pm I wouldn't remove that floor crossmember Rich unless you absolutely have to... sure you could drill out the spot welds and fetch it out but you'll only have to plug weld it back in afterwards. If I was detailing with that rust around that item I'd clean as much rust back as possible with a wire wheel on an angle grinder then floor it with rust converter to kill the rest of the rust... afterwards wash it off and when dry give it a good coat of either zinc primer or POR15.... unless there are holes under it that I can't see in the photo
