hi guys anyone no if the f+r shocks fit all the FB`s ?
Re: hi guys anyone no if the f+r shocks fit all the FB`s ?
Rears fit everything. Fronts come in two versions... to fit 79-80 S1 (I believe the struts are slightly taller so the shock body is longer) and 81-85/6. S2/S3
Koni did a clever thing with their RX7 (SA/FB) front insert and put an extension peg at the base which could be snapped off to make the whole thing shorter so that could be used throughout the whole model range.
