will oem fd calipers & discs fit my S3???
hi will they fit with brackets made up & the disc re drilled to 4 stud??? cheers mick
Re: will oem fd calipers & discs fit my S3???
There is a kit from respeed for FC discs, calipers are the same as FD anyway but you will need some EFI hubs from the US to keep the 114.3x4 studs
95 FD RS in black
just wanted biggers discs 294mm fd compared to fc 274mm, so the fd discs wont fit over the hubs with it re drilled to 4 studmpk490p wrote:There is a kit from respeed for FC discs, calipers are the same as FD anyway but you will need some EFI hubs from the US to keep the 114.3x4 studs
