12 oil metering pump
Has anyone rebuilt one of them mine is leaking and need to fix it. Is it easy sorry for the bad pic phone takes shit pictures at night.
Re: 12 oil metering pump
It depends where it's leaking from.
The hoses can split.
The gasket between the pump and front cover could be damaged.
Or the pump itself could be leaking.
If it's the last one, you can get rebuilt ones from Atkins Rotary.
TOOL wrote:It depends where it's leaking from.
I checked the hoses today and they are perfectly fine. I found online how to rebuild it guy shows you how and the type of o rings to get so I'm give it a try and see how it goes. Thanks for the info
