elford rebuild
rip7
elford rebuild
Post by rip7 »
just checked the end play on the shaft, but only 0.02 [ should be 0.04 0.07 ]the only things changed to effect this are the torington bearings. could it be them.the shaft has a y sleave fitted. so i think i might need a x spacer. or refit the original torington bearings.[ they were like new] any one got a x spacer.
Re: elford rebuild
You sure it's not pinched?
rip7
Re: elford rebuild
Post by rip7 »
i dont think it pinched. i will check all again monday. too cold in the workshop the vasalean has gone solid
Re: elford rebuild
Easily done.
Changing the torrington's shouldn't affect your end play. If you had more play I would say don't worry about it.
rip7
Re: elford rebuild
Post by rip7 »
checked yesterday, not pinched, i did put 2 replacement housings on this rebuild so must be them. so i think a k or x spacer is needed any body got one, cheers all
apexheid
Re: elford rebuild
Post by apexheid »
rip7 wrote:checked yesterday, not pinched, i did put 2 replacement housings on this rebuild so must be them. so i think a k or x spacer is needed any body got one, cheers all
What kind of housing. iron or rotor housing. if you don't changed the iron and the end play will be fine.
If not, you got another iron plate and it will a@@@ (spelling) the end play.
rip7
Re: elford rebuild
Post by rip7 »
no just changed the rotor housings, .can the new torrington bearings be thicker, will check again
Re: elford rebuild
rip7 wrote:the only things changed to effect this are the torington bearings.
rip7 wrote:no just changed the rotor housings,
Changing the housings or plates will affect end play. Same as lapping.
I can see what I have lying around next week. Just as easy to go to Mazda. They're not expensive.
apexheid
Re: elford rebuild
Post by apexheid »
Ah! rotor housing always stay the same unless remove mat'l for some reason.
rip7
Re: elford rebuild
Post by rip7 »
tryed mazda for spacers, now all discontinued, so will have to get one spun up on a lathe, cheers all
